Maybe it’s just me… but when I run the Weather WatchDog and WD crashes and restarts it spawns off another WD Watchdog… is there any way to prevent this?
Thanks!
Thanks!
Did you ever get a chance to check this out Brian? I think WeatherD watchdog needs to check to see if it is already running before it starts to prevent multiple instances of itself starting…
Thanks!
ah, ok, i did miss this post (the check all unread posts sometimes does not work)
i will have to look into this…
