Waetherflow Tempest on ubuntu
i can’t get consolewd to work with thempest on ubuntu 18.04
it seems like it dosent read the config file correctly. it does not find the correct id or something?
Or maybe i am not using correkt linux version. i use “Weather Display for Linux console 64 bit Linux desktop Version on 23 August 2021 - 12:03:32”
And i am running only console version of linux.
it should work
I will test here
what do you see happening exactly?
try a new update and let me know
after the update you did. its working.
the old version did only start cronweatherflowconsole. but did not do anything more.
thanks for quick reply and fix
I can’t see rain from the tempest station.
Is there some settings i can use in the config.txt file to fix this.
Also when the wind is 0, it report wind direction 0. And that makes the average wind direction wrong.
Any solution for linux version to fix this?
I tryed search the forum for answer, but cant find solutions for linux console version.
Maybe i am not searching the right words
i am not exactly sure what you mean when you say you cant from tempest station…what rain exactly?
the more detailed info you can provide the better
re the wind direction…its just using what is provided, by the hardware, but I could use the last wind direction reading
It is not geting any type of rain. not dayli, monthly, yearly, rain rate. all is showing 0
How can it be set to use last reading and not 0. for the direction? in the config.txt file
here is the clientraw file and a pic of FreshWDL.
12345 0.3 0.0 0 8.4 87 1015.1 0.0 0.0 0.0 0.000 0.000 0.0 0 0.0 0 0.0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 16 53 45 Strand_-_Sortland-16:53 0 16.8 1 9 0 0 0 0 0 0 0 8.4 8.2 8.7 6.8 0 Dry 0.1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 1 0 0 0 0 0 3.0 6.4 840.2 1/9/2021 8.6 6.4 8.7 6.8 0.5 1 0 1 1 1 1 0 1 1 0 8.3 8.4 8.4 8.4 7.9 7.8 8.0 8.4 8.7 8.4 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 8.7 6.8 8.4 1.9 0 --- --- 23 0 0 0.0 0.0 0 0 0 0 0 84.0 0.0 0.0 10.0 1015.2 1011.9 3 15:10 15:10 7.1 6.0 6.8 5.3 1 2021 2021 1 -1 1 324 186 232 335 70 41 0 31 19 19 0.0 0.0 0.7 7.5 69.0 15.0 0.0 97 83 0 04:04 0 0 0 0 0 0 3.9 16:46 04:04 !!CWD_console_22.2!!
consolewd stores its own rain totals
you can set the starting totals in the config setup
when it rain , as the program is running, those totals should increase
you can't and I am not sure how you got the impression you could from my last post? its something I would need to change in a future update
