I’m using the VPet value in a custom file and it is showing 0.000
I just upgraded to 10.17v to see if it made a difference and it is still a 0.
WD is reporting that it is 0.157 in so far for the day.
Also, while there appears to be a Solar %, there doesn’t appear to be a way to get the Solar Value from VP. The WD display shows it at 128 but I don’t see a tag for it.
I don’t know how you keep up with all this stuff , requests and development at the same time. However you are doing it… keep up the good work.
