A heartfelt plea to template designers: please be aware that centring, e.g., 15° does not work, visually. You probably need to add a thin or en space in front, so that the number is centred.
Problem is exacerbated by using typefaces where 1 is narrower than 2. . . numbers should always be the same set width.
