Version 1037 WD -> Ok now
Does anyone have version 1037 WD, it seems to be the only one that will run on my old pc…without locking up or crashing the machine… need the zip also…
did you see the thread where i have improved a lock up problem some people were having?
(latest .zip version)
If the current version won’t work for you, but do try it first as if it will you will have a much better product, then I have old versions at the following location including 10.37.exe (don’t have the .zip for 10.37 however)
http download is here:
http://JaxWeatherCam.net/WD-Past/
I also have created a FTP Read Only Login for that directory (if you would rather use FTP rather then http download):
ftp.JaxWeatherCam.net
username: xjaxweathercam-WDPast
password: weatherdisplay1
(User and Password are cASe sensitive)
Thanks for the info… I will try again… so far 1037f build 11 is working OK…
Had to switch to Metar update as last night lightening storm fried my old Ultimeter… My wife , got on ebay this am and bought a lacrosse 2310 for me, not what I would have done but pretty nice…
Thanks again…
Alan
the fix for sometimes crashing is in build 12 or later
you should really be using that
Well feeling pretty dumb at this point… Seems that one of the memory sticks in computer was going bad. Didn’t see it till it quit completely, fortunately have a bunch of memory… Up and running again will try the newer versions
Alan
PS.
1037F build 13 up and running flawlessly 24 hrs…
Thanks again
