Version 10.37Q bulid 34 does not work for me anymore.[RESOLVED]
It has not done since March 3 to 4. This was much more rapid once before for me too, then it was the barometric pressure was the cause, it was offset error. Perhaps that is the same now, but it was wrong then is right now in the offset.
What happens is that, nothing is updated, nothing appears except the maximum wind, for this day, maximum wind last hour and a maximum Average wind.
In the graph of the barometric pressure is constant at 1013 mb but Konsolen Vantage Pro 2 Wireless as it says on 1026.2 so what makes it so that it is now. Should be okay and got this up and running.
No data will be over before either of the console, the only thing that is updated is that WD accept all that has been logged and records this. But nothing happens or does not do FTP program starts up.
Have now downloaded the latest patch also exe zip update, but nothing helps.
Virus programs and other programs are shut off before innstalasjon and WD is started up as Administrator.
We apologize for any typos here. English is not my strongest side.
Greetings
Ole
The problem is solved, the error was that I had crossed in the CWOP settup, that I’d use the barometric pressure from WD.
Thanks Brian
Cheers from
Ole
the latest update checks for a corrupted last altimeter barometer reading, now
