Values
Hi WD,
The values in the graph on the main screen WD, are these one minute average values?
I ask because when i see a max temperature registration in the min max data field on the main screen WD, its a moment max, not a minute average max, am i right?
they are but the max gust line will show the max gust for the day
Hi thanks.
Is it perhaps possible to have the min/max value(s) (except the wind) show max/min from a minute Average?
not sure what you mean?
Hi WD,
Im not sure if the max and min temperature values in the extreme conditions datafields on the main screen of WD are 1 minute average or as they happen.
Sorry if ive been not clear.
I have some other questions about a sensor, but i will start a new topic later on.
they are as they happen :wink:
Ok clear, thanks for your help.
I can set loggernet/Campbell to output running 60s average values for temp and hum and have WD to read and process thema fine.
The one thing i cant get to work properly is the recording of the precipitation. I see at the time WD is refreshing graphs etc. (Every end or beginning of the minute) WD stops getting data.
What i see is cronpakbusnew is updating fine, doesnt miss data.
I just realize i have a separate topic about this… #-o sorry…
