Value reset and update charts
I don’t know if is only my problem but i cant stay with PC turned on 24 hours a day, i need to shut down during night and restart next morning.
But (this is my 3 day using weather display trial) when i start next morning i do “Daily reset values” in Action\reset extrems. But Temp/wind/chart and sunshine hours evaportranspiration chart does not update with values of past day. Values only reset (and than update all charts) only if PC is on all the night and so at 0 night automatically resets values and put in memory values of past day.
Any solution?
what weather station type?
I Have Oregon Sientific WMR 928N
ah, that is the reason…that station does not store any data…
when you restart wd, you can click on action, reset daily extremes
i guesss i could make it so it does that, as an option, when wd first starts
Hi Brian
i guess i could make it so it does that, as an option, when wd first starts
ie tick if required
any clues as to wd not talking properly to datalogger (skyview) for 928
skyview:
do you have all the settings corect in the skyview data logger, for a wmr918 type station?
i don thave a skyviewe data logger
so i am a bit blind, i.e you will need to give me a good run down on what is and what is not happening
