It is a bright, sunny, dry morning with a gentle breeze and I have just installed Ver 9.94e over my 9.93 version.
The programme is now recording some very strange readings - apparently the temperatures soared to 145 degrees F, the wind has gusted to 64 mph and it has been raining heavily!
I have never had a problem with updates before - can anyone give me some advice?
did this occur with the data extraction at start up or the live data?
(i did make a small change with the data extraction, I was trying to auto determine the logging interval, but failed…maybe that upset things
Didn’t seem to work properly for me depending on the pressure there was a different offset each time…
are you using the same formula for the history data that kenneth has?
(Pressure= 1002.2 + (value % 10000)/10. If pressure is greater than or equal to 1502.2 then you subtract 1000.)
I’ll try some experimenting and see if it makes sense in terms of that…
yes i am , but the history raw pressure base is different to that i have used for live data
anyone else seeing crazy readings ?
do they settle down john?
can you go back to 9.93 and see if it happens agian?
what barometer pressure do you have at the moment?
