Hello again,
i do have a problem with the uv sensor. The unit works correct and here is no sunshine at the moment.
Unfortunately it shows some curious things as you can see in the attached file.
Strange that it shows data from a date that is in the future.
Regards
Jose
it will be due to the fact that Feb only has 28 days
I will investigate
Thanks for looking.
One problem seems to be solved by its own.
The recordings for future dates aren’t there any more.
But there are recordings which never could have been recorded.
Regards
Jose
yes
see my post above (the problem is there is only 28 days in february (and so , when it tries to plot the last 28 days, the data is not correctly shifted along those 2 missing days)
Well and what is about the incorrect data from day 25 to 27 (day 26 appears two times) or do you mean that?
My English isn’t that well so I might have problems to follow some times.
Regards
its the same issue
because of only 28 days in February
I will investigate
your patience is appreciated
I can wait. Still impressed about the great job for the program and the forum.
Regards
Jose
try a new .zip update
should be better now
I’m not sure, but isn’t there anything going wrong …
Actual date is 8th of march and I refresh everything in WD.
Nevertheless it shows me the UV readings from the 6th only.
Should there not be the 7th up to date?
Regards
Jose
