UV and lightning blocks
In easyweathersetup you can select to save your own graph data in . . ./chartsmydata or you can get the data from WU and store it in . . ./chartswudata. Which have you selected?
Your status array says there is no mydata to be found yet, and wudata has been stalled for 48 days. . .
CORRECTION: your status array has been stalled for 48 days too. Are you running the station cron job?
I had it set to data by default and now I set it to WU and that was the solution.
That was part of the solution. . . please confirm which of the 4 WU IDs shown in PWS_module_test.php you are actually using, because there does not seem to be any 2025 data.
Are you running the station cron job? You will not get history without it.
And delete . . ./_my_settings/status.arr – it will be rebuilt.
I created a cron job via my hosting provider.
It is now set to every hour, unfortunately I cannot set it shorter.
Do you happen to know the command to enable it to run every minute???
Run it every 5 minutes.
Running it faster does not improve things much.
Use Free cronjobs - from minutely to once a year. - cron-job.org
It is free and very reliable.
Thank you Wim.
It works perfect via free cronjobs
