I have jpg images usually less than 40kb from one of my cameras tied into another program I can use as a weather cam for photos.
I want to have WD get this file from a different directory when I give it a path to that directory - example
if you use the 3rd party web cam setup, you set the source and destination directory/filenames, separately
Windy I can
is the image available as a file?
Yes it
then you can use it
you set the file as the source file in the 3rd party web cam setup and then set a new file name and location as the destination file, there
I understand what you are saying now - jest have to find where everything is at now
