Using Email to notify of events
Good morning all from a bloody warm, if not hot, Sonoran Desert!
I’m playing around with Email notifications of certain events. I think I’ve got it working in test mode, and I’m waiting for ‘real life’ messages to begin.
Ideally, what I’d like to do is send an email each day at 1700, and recap the high temp, low temp and humidity, cloud (if any) condition.
I “think” - therefore I ask! (experience!) - but this can be done, right? I suspect the 'custom message.txt file can be built to include these variables, and then sent out. Am I on the right track?
Ken
Ken,
You are on the Right Track with the Custom message idea. I send out a morning Custom Email from WD, automatcially, that appears as follows:
[quote]DAILY WEATHER REPORT FROM JaxWeather.net - 07:00, 03/17/07
Weather Forecast:
today sunny…windy…cooler. highs in the lower 60s. northwest winds 15 to 20 mph with gusts to 30 mph.
tonight mostly clear. colder. lows in the mid 30s inland… around 40 coast. northwest winds decreasing to 5 mph.
Current NOAA Alert/Warnings:
Lake Wind Advisory
Sunrise: 7:34 - Sunset: 19:36
Total time of possible sunlight today: 11:56
Moonrise: 6:35 - Moonset: 18:09
Moon Phase: 4% - Next Full Moon: 3 March 2007
Current Conditions: clear - Cold
Current Temperature: 44.9
Bob,
that’s very close to it, though yours provides more info than I had planned on.
So, now I know where and how, I’ll pick your brain if I run into roadblocks
Ken
Just checked my test email account. I set my initial test temp fairly low, about 84 F, and it seems the program has been sending me an email every hour that the temp is over this figure. Is this normal? Is there a switch (is it the send once per day one on the Main Setup Tab?) that will only send it once, when the temp is met or exceeded?
Ken
Ken there is a big difference in Daily Weather Report emails and Warning emails and mine is set only as Reports and you specify the time and WD sends it at that time every day.
Bob,
I’ve just looked thru WD, and I can’t seem to find the “report Emails”. I found the warning ones okay, but at a loss for reports.
Where is it in the Options?
Ken
Ken,
I don’t use it myself, but if you go view-averages/extremes, the 6th tab over seems to be what you’re looking for.
  • Jim
Control Panel - FTP - Weather Report Email
Thanks Guys!
Ken
