use this to convert wlk to wd log files..
…especially if the import function doesn’t do it due to missing data.
it’s only an amateur job so feel free to use and improve!
feedback most welcome!
  1. export the monthly data in WL to a txt file and then open as an excel document.
  2. copy this into the yellow area in the ‘converter’ (you can drag down the rows if you have more data)
  3. hey presto column A and B give you the log file data and also the indoor data
  4. copy one of these to notepad and save
Please feedback if i have overlooked anything!
http://www.maidenerleghweather.com/wlktowd.xls
“export the monthly data in WD to a txt file” should that WD be WL?
good spot. you are correct.
thanks
#-o
I haven’t worked a lot with WL.
How do I load my 2010-01.wlk in Weatherlink and where can I find this export function.
not got it in front of me but is it
browse
export
OK, got it.
It was the “Browse the station data” icon.
A new “Browse” menu appeared, then Choose Date.
Thanks again.
no worries.
i would appreciate feedback for anyone who tries it.
if there is anything it could do better or does wrong, then please let me know and i will have a go.
