Sounds like the logger is set for USBxpress mode, WD needs it to be in virtual serial port mode. Changing mode is either a menu option in WL, or a utility supplied with WL.
I have set the communication port in WL to ‘Serial’ and made it search for the datalogger - but it does not find the logger. When I set the communication port in ‘USB’ and click Test botton it finds a Davis Weather Station.
Do I need to change anything else in WL? (I suppose I should set port to ‘Serial’?)
After installation i still dont see any change under COM-ports in Device Manager - I only see “USBexpress devise” under USB devices. Weatherlink cant find any datalogger under search for serials in communication port setup.
Im not sure what else to try?
Henrik
Ps. We have tried changing the datalogger to another USB port on the computer.
Niko: Thank you very much - you made me look thru the hole setup once more and now I saw the utility software. After running that the computer found the datalogger on COM port 4
