I would like to upload only WAP file and not classic HTM file.
How?
there is the facility to upload a wap page
(see mine: Weather Display - the Weather Station software )
in the setup, ftp/internet setup
(tick use usa standard most likely)
or, you can create your own template (waplocal.txt)
or
you can not use the wap, but instead use the custom web page feature, and use the facility to set the file extension and the remote name (do the later (i.e set the remote name) under setup, customise internet and file creation setup)
there is the facility to upload a wap page (see mine: http://www.weather-display.com/windy/wap/index.wml ) in the setup, ftp/internet setup (tick use usa standard most likely) or, you can create your own template (waplocal.txt) or you can not use the wap, but instead use the custom web page feature, and use the facility to set the file extension and the remote name (do the later (i.e set the remote name) under setup, customise internet and file creation setup)
Good Windy, but I just like to upload wap page, how can I prevent WD from uploading standard HTM page either?
Cheers
i would use the setup, customise internet and file creation setup
there you can set the ftp upload times just for a custom page only
i would use the setup, customise internet and file creation setup there you can set the ftp upload times just for a custom page only
Ok I’ll proceed per your advice then
Thx
Tried but no luck.
Please would you post a dumb-proof complete procedure?
go action, back up registry, click on back up, then email m ethe file wdisplayftp.reg
from the databack up folder
and i will have aa look at what you have done
thanks
i have screen shot of the customise internet file creation and upload screen (see under setup)
I have your settings, but you need to turn on the override switch, and then for the wxlocal.html file, click on set for file update times, and set that, and then click on set for file upload times, and set that
and change the remote file to name to say index.wml
and have a file called wxlocal.html, in the web files folder, that has the custom tags and the wap html code
i have screen shot of the customise internet file creation and upload screen (see under setup) I have your settings, but you need to turn on the override switch, and then for the wxlocal.html file, click on set for file update times, and set that, and then click on set for file upload times, and set that and change the remote file to name to say index.wml and have a file called wxlocal.html, in the web files folder, that has the custom tags and the wap html code
Ok, pretty clear now.Thanks
One stupid question then: what I’ve done with wxlocal.html could have been done with wxlocal2.html instead, right?
Then: given that the only setting that has been modified is the one told by you, now I should expect that no other stuff is uploaded except the wml file, right?
Just a nuance: " Override" reads “Overide” when ticked.Typo.
Huge thanks Brian
no such setup customising here Brian :roll: did I missed anything ?
setup, contro panel, customise internet file and creation and upload
after upsizing that page it was there ! ooops :oops:
that new size will be saved
