Uploaded images cuttoff
10.31n & m
I’m having a problem with the uploaded images being cutoff at the bottom. The local ones look fine.
It’s almost like it quits uploading the file before it finishes? I have upped all the timeouts in FTP, but cannot figure this out.
Also, when doing these uploads should all the files be uploaded during one FTP session? It seems mine is logging in and out for every single file.
Anyone else having similiar issue? Thanks for any info
could you post here what appears under view, ftp log?
also have you installed the full version to get the latest ftpupd.exe program?
If you are running winXP you may need to make the active title bar smaller.
This is if it is images like the All Time records ect.
:smiley:
the thing is though he said its OK in the web files folder
the fact wd is logging in each time make me think he has ticked to use these ftp servers in the customise internet and file creation setup
untick that
also ticking to rename the file in the connections setup in the ftp /internet setup might help too
Oh my goodness -
I’ve been fighting with my all time records windows for a long time being slightly cut off at the bottom.
That did the trick for me
Thanks for sharing that!
Hmm… the realtime ftp works just fine. 24/7 I have installed the full build several times.
The FTP log does not look good. This is strange because it had been working for weeks. I shutdown the firewall on the server just to make sure and I have not touched pure-ftpd that I remember :?
It looks like the file does not upload if you are just looking at the logs. The files partially upload from what I can tell so I get the cut off image.
I have tested with other FTP clients and everything works fine on this account and many others so I’m not sure what else to check on the server, but I’m still digging around.
This is what I see on the server in /var/log/messages which is strange… I’m going to ask around.
You can see the regular FTP failing here.
Jan 15 12:35:26 host pure-ftpd: [ERROR] Error during read from data connection: Connection reset by peer
Jan 15 12:35:26 host pure-ftpd: [INFO] Timeout (no new data for 1200 seconds)
Jan 15 12:35:26 host pure-ftpd: Jan 15 12:35:27 host pure-ftpd: ([INFO] user is now logged in
Jan 15 12:35:28 host pure-ftpd: [ERROR] Error during read from data connection: Connection reset by peer
Jan 15 12:35:28 host pure-ftpd: [INFO] Timeout (no new data for 1200 seconds)
And the Realtime FTP working fine. I never have problems with this and it’s running 24/7
Jan 15 12:35:37 host pure-ftpd: [NOTICE] clientraw.txttmp uploaded (580 bytes, 2.79KB/sec)
Jan 15 12:35:37 host pure-ftpd: [NOTICE] File successfully renamed or moved: [clientraw.txttmp]->[clientraw.txt]
Passive checked and unchecked have same result
*******list of files uploaded********
C:\wdisplay\webfiles\weather.html
*******actual messages from upload session********
***Start Time/date***:12:35:14 PM 1/15/2006
alz025.txt
Permanent connection selected
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do....
***Time/date***:12:35:16 PM 1/15/2006
Logging onto FTP server....ftp.currentweather.info
Connecting to FTP server.
Connected.
220---------- Welcome to Pure-FTPd [TLS] ----------
220-You are user number 2 of 50 allowed.
220-Local time is now 12:34. Server port: 21.
220-This is a private system - No anonymous login
220 You will be disconnected after 20 minutes of inactivity.
USER=****
331 User  OK. Password required
PASSWORD=****
230-User  has group access to:  currentw
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Checking for next FTP agenda....
there are 1 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PORT 192,168,0,167,19,47
200 PORT command successful
STOR weather.html
150 Connecting to port 64017
421 Timeout (no new data for 1200 seconds)
141: 421 Timeout (no new data for 1200 seconds)
PORT 192,168,0,167,19,48
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,50
150 Connecting to port 64020
PORT 192,168,0,167,19,51
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,53
150 Connecting to port 64023
PORT 192,168,0,167,19,54
Disconnected.
301: Interrupted
Connected.
220-Local time is now 12:35. Server port: 21.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,57
150 Connecting to port 64028
PORT 192,168,0,167,19,58
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,61
150 Connecting to port 64031
PORT 192,168,0,167,19,62
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,65
150 Connecting to port 64034
PORT 192,168,0,167,19,66
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,68
150 Connecting to port 64037
PORT 192,168,0,167,19,69
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,73
150 Connecting to port 64041
PORT 192,168,0,167,19,74
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,77
150 Connecting to port 64044
PORT 192,168,0,167,19,80
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,84
150 Connecting to port 64047
PORT 192,168,0,167,19,85
Disconnected.
301: Interrupted
Connected.
USER=****
PASSWORD=****
TYPE I
PORT 192,168,0,167,19,87
150 Connecting to port 64050
No more files to upload
All Agenda complete, doing FTP log off....
FTP logoff
QUIT
Disconnected.
Doing abort procedure/program close...
STOR weather.html 150 Connecting to port 64017 421 Timeout (no new data for 1200 seconds) 141: 421 Timeout (no new data for 1200 seconds)
i would say that your ftp server now needs passive mode,a change they have made with out telling you
tick to use passive mode in the connections setup in the ftp/internet setup
or a firewall is blocking it
It’s actually my server and passive is enabled in pureftpd and I disabled the firewall on the box to test.
I have tried it with passive checked and unchecked. I’m not sure what to do because it had been working and I can ftp all day with another client.
I was thinking if it was server related I would have issues with realtimeftp and other ftp clients and other hosted accounts.
O’well Thanks for the tips… I’ll just use WDL/clientraw for now :slight_smile:
you will find its a firewall somewhere blocking it or its the passive mode option…
after ticking that, re post here that ftp log latest report
i.e it should mention about passive mode
Thanks Firewx
Looks like it’s fixed. I still don’t know what I changed other than trying to change the size of the summary.gif height and width, but what the heck it’s fixed.
Thanks again
Cheers
MikeyM
:D/
