The current month file is named dailynoaareport.htm
Other months are named dailynoaareportMMYYYY.htm. Note that the months are not padded so that Jan would simply be like dailynoaareport12009.htm with no zero padding for the month.
To recreate use View → Avg Ext/Noaa Reports → 2nd Tab for Noaa Style Reports.
Select which date you want to recreate in the Select Date to Calculate Field.
Click the update dailynoaareport.htm button. If it is not for the current month, you will need to rename it (outside of WD) to the correct month/year.
To recreate the climatedataout files is similar. Select the Detail Climate Report instead. You will not need to rename the climatedataout files as they are saved with the appropriate month/year.
If my memory is correct, to upload the dailynoaareport and climatedataout files select Control Panel ->FTP & Connections ->Web Files Upload Times and Av/Ext. Check the do daily uploads of averages/extremes and in the boxes below set the time to be uploaded - normally a few minutes after midnight.
I must have something set wrong in my snow summary and snow detail pages. It looks like the report in converting the snow amounts from IN to CM. Has anyone else seen this?
The problem is fixed in the WD Nov. reports, must have been fixed in the latest version. I adjusted the data for Oct and all is well at johnsnhweather. It’s SNOWING!!
It looks like the script is unable to find the noaadata.csv file.
Warning: fopen(/www/home/silkeborg-vejret.dk/scripts/noaagrafer/cache//www/home/silkeborg-vejret.dk/scripts/noaagrafer/noaadata.csv) [function.fopen]: failed to open stream: No such file or directory in /home/www/silkeborg-vejret.dk/scripts/noaagrafer/wxnoaacsvdata.php on line 248
Make sure you have the $cache_location set to wherever you have the noaadata.csv file.
The noaadata.csv file you are using is the sample one with my readings. Make sure it is writeable. Once it is writeable, force an update by adding “?force=1” at the end of graph url.
