Update WD
There is a correct procedure tu update WD?
Tank you
Tom
  1. Exit & Save from the main WD screen.
  2. If you use the clientraw.txt or MySQL update functions, look on the system tray (right hand end of the task bar), double click on their icons and then close them down using the ‘X’ icon.
  3. Run the WD installation program that you’ve downloaded and it should update without problems.
Tom,
There is a FAQ regarding updating WD:
(Maybe that ought to be a sticky Chris? )
That’s a good heads up there Chris - I added this to the FAQ (making sure that none of WD’s applications are not running in the system tray).
