Hi, my internet doped out today for about 6 hours, how do I up load the missing data to WG. all the data is on the computer but not sure how to up load it.
many thanks
teal
that should happen auto, if WD got the missing data from the data logger, then at the next WU auto update, that missing data should then get uploaded
(make sure you are using the cronwdwu.exe that fixes that not working)
otherwise there is a function to upload past data under control panel, wunderground setup
Hi windy had to up date WU manually, clicked on every 10 Min’s clicked on go, but as soon as the green bar filled up WD crashed, then a banner came up saying please tell microsoft ETC send don’t send, WD then restarted & all was well, when I checked WU it had updated the missing data but by every hour not every 10 Min’s not much of a problem, but now since the restart the counter next to the data received box is stuck 2628 it is not counting up any more, data received box is flashing OK & WD is working all data, graphs, wind, uploading to WU ETC are all working OK, using ver.10.37 b34.
many thanks
teal.
