Hello,Just wondered if anybody can help me i have tried to get wd v10.17 to save the WXNOW.TXT for ui-view so that i can run a weather station,i have tried everything i can think to save a file but no joy,can anybody tell me what is wrong with it. 8)
when you choose the directory, you need to double click it, so that it then shows in the bottom white box correctly
try that
(i just did myself, and it works just fine)
do you have data appearing on the main wd screen>?
i.e what weather statiion type do you have?
email me your settings file, wdsiplay.ini, from c:\windows or c:\winnt
also, did you click on Save in the aprs output setup screen?
also, check you dont have wd set to output via the com port
my mistake
if you go action, back up registry entry now, then wd creates a copy of the wdisplay.ini file in the folder databackup, which is a sub folder created when you do that, of where WD is intalled
you have it set to output via the com port
you need to turn that off (as I suspected)
(i.e,setup, produce a aprs output file, setup com port output of the data to a TNC, and then turn the switch there off )
and then restart wd
