I have a 2nd older WeatherFlow that I have deployed at my site and is on the same network as my main Tempest station. It is also using it’s own hub so it shows on the Tempest website as it’s own weather station.
However, because I had been using “Use direct UDP from Hub” option, it’s feeding both hubs data into WD when I only want the StationID I set in WD to come through Cronweatherflow. Is it possible two have two hubs on the same network @windy2 ?
Or is my only option to disable the direct UDP feature…or get creative with trying to restrict/block the IP address of the 2nd hub using firewall rules so WD doesn’t keep pulling that information in?
Here’s a snippet from Cronweatherflow where you can see both getting captured simultaneously:
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663858,1.50,291]}
4:04 pm December 20 2024
Wind gust 1.5
Direction 291.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663857,1.94,338]}
Wind gust 1.9
Direction 338.0
4:03 pm December 20 2024
Barometer 997.7
temperature 21.7
Humidity 69.0
Strike 0
distance 0.0
Battery 2.590
Uv 6.2
Rain 0.000000
Wind lull 1.2
Wind avg 2.9
Wind gust 5.4
Direction 328.0
Battery 2.590
solar 588.0
UDP data {"serial_number":"HB-00025276","type":"hub_status","firmware_revision":"194","uptime":557852,"rssi":-57,"timestamp":1734663860,"reset_flags":"PIN,SFT,HRDFLT","seq":55741,"radio_stats":[25,1,0,3,49385],"mqtt_stats":[17,0]}
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663861,0.56,126]}
Wind gust 0.6
Direction 126.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663860,1.38,329]}
Wind gust 1.4
Direction 329.0
UDP data {"serial_number":"SK-00002436","type":"device_status","hub_sn":"HB-00001661","timestamp":1734663860,"uptime":106380,"voltage":3.187,"firmware_revision":43,"rssi":-78,"hub_rssi":-82,"sensor_status":0,"debug":0}
UDP data {"serial_number":"SK-00002436","type":"obs_sky","hub_sn":"HB-00001661","obs":[[1734663860,59059,3.88,0.000000,1.01,2.56,3.87,4,3.187,1,492,null,0,3]],"firmware_revision":43}
Uv 3.9
Rain 0.000000
Wind lull 1.0
Wind avg 2.6
Wind gust 3.9
Direction 4.0
Battery 3.187
solar 492.0
UDP data {"serial_number":"ST-00010939","type":"device_status","hub_sn":"HB-00025276","timestamp":1734663862,"uptime":617779,"voltage":2.592,"firmware_revision":181,"rssi":-67,"hub_rssi":-64,"sensor_status":10751,"debug":0}
UDP data {"serial_number":"ST-00010939","type":"obs_st","hub_sn":"HB-00025276","obs":[[1734663862,0.56,3.44,5.71,335,3,997.75,21.61,68.80,60477,5.20,504,0.000000,0,0,0,2.592,1]],"firmware_revision":181}
Barometer 997.8
temperature 21.6
Humidity 68.8
Strike 0
distance 0.0
Battery 2.592
Uv 5.2
Rain 0.000000
Wind lull 0.6
Wind avg 3.4
Wind gust 5.7
Direction 335.0
Battery 2.592
solar 504.0
UDP data {"serial_number":"HB-00001661","type":"hub_status","firmware_revision":"169","uptime":105105,"rssi":-56,"timestamp":1734663862,"reset_flags":"BOR,PIN,POR","seq":10507,"fs":[1,0,15675411,524288],"radio_stats":[2,1,22,3,0],"mqtt_stats":[1,0]}
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663864,1.66,276]}
Wind gust 1.7
Direction 276.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663863,1.13,331]}
Wind gust 1.1
Direction 331.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663867,1.65,293]}
Wind gust 1.6
Direction 293.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663866,1.41,341]}
Wind gust 1.4
Direction 341.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663870,1.69,264]}
Wind gust 1.7
Direction 264.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663869,1.55,4]}
Wind gust 1.6
Direction 4.0
UDP data {"serial_number":"HB-00025276","type":"hub_status","firmware_revision":"194","uptime":557862,"rssi":-57,"timestamp":1734663870,"reset_flags":"PIN,SFT,HRDFLT","seq":55742,"radio_stats":[25,1,0,3,49385],"mqtt_stats":[17,0]}
UDP data {"serial_number":"HB-00001661","type":"hub_status","firmware_revision":"169","uptime":105115,"rssi":-57,"timestamp":1734663872,"reset_flags":"BOR,PIN,POR","seq":10508,"fs":[1,0,15675411,524288],"radio_stats":[2,1,22,3,0],"mqtt_stats":[1,0]}
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663873,1.66,286]}
Wind gust 1.7
Direction 286.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663872,1.27,12]}
Wind gust 1.3
Direction 12.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663876,1.17,49]}
Wind gust 1.2
Direction 49.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663875,1.54,331]}
Wind gust 1.5
Direction 331.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663879,0.94,356]}
Wind gust 0.9
Direction 356.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663878,1.68,348]}
Wind gust 1.7
Direction 348.0
UDP data {"serial_number":"HB-00025276","type":"hub_status","firmware_revision":"194","uptime":557872,"rssi":-57,"timestamp":1734663880,"reset_flags":"PIN,SFT,HRDFLT","seq":55743,"radio_stats":[25,1,0,3,49385],"mqtt_stats":[17,0]}
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663881,0.48,0]}
Wind gust 0.5
Direction 0.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663882,2.76,324]}
Wind gust 2.8
Direction 324.0
UDP data {"serial_number":"HB-00001661","type":"hub_status","firmware_revision":"169","uptime":105125,"rssi":-58,"timestamp":1734663882,"reset_flags":"BOR,PIN,POR","seq":10509,"fs":[1,0,15675411,524288],"radio_stats":[2,1,22,3,0],"mqtt_stats":[1,0]}
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663885,3.89,289]}
Wind gust 3.9
Direction 289.0
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663884,1.67,25]}
Wind gust 1.7
Direction 25.0
UDP data {"serial_number":"AR-00005486","type":"device_status","hub_sn":"HB-00001661","timestamp":1734663884,"uptime":106504,"voltage":2.756,"firmware_revision":20,"rssi":-64,"hub_rssi":0,"sensor_status":4,"debug":0}
UDP data {"serial_number":"AR-00005486","type":"obs_air","hub_sn":"HB-00001661","obs":[[1734663884,721.50,24.72,81,0,0,2.756,1]],"firmware_revision":20}
Barometer 721.5
temperature 24.7
Humidity 81.0
Strike 0
distance 0.0
Battery 2.756
UDP data {"serial_number":"SK-00002436","type":"rapid_wind","hub_sn":"HB-00001661","ob":[1734663887,0.48,0]}
Wind gust 0.5
Direction 0.0
UDP data {"serial_number":"ST-00010939","type":"rapid_wind","hub_sn":"HB-00025276","ob":[1734663888,3.85,316]}
Wind gust 3.9
Direction 316.0
