Apologies if I’m missing something obvious, but where are the basic set up instructions for setting up a twitter feed from WD? The wiki page doesn’t have anything and neither does the PDF wiki. Any ideas?
Setting up Twitter from WD is pretty straight forward.
The biggest issue has nothing to do with WD but has to do with installing .NET 4 framework on the computer WD is running on, which is a twitter requirement.
Set your username and password for twitter, set times and Turn the Main On
Then once you have .NET 4 Extended (see this post http://discourse.weather-watch.com/p/415655) installed then you would click on “Setup oauth for the first time use” from the WD Twitter setup screen.
Many thanks Bob! WIll give it a go.
I added a FAQ for setting up twitter for first time
