I am getting blank boxes for last month in the trends.gif, have not had anything in them since the month change.
I’m getting values for all the fields except for last year. Shouldn’t it have a value for last year?
its all good here for me
check you have last years this months data file greg in your data files folder
i.e
month13002.inf
and
jeep, you should have month122002.inf
and try a program restart
but i do a test to make sure that is the file its actualy looking for…
i ran through the compiler and tested, and it is looking for last months data file OK, so thats good
No file named month13002.inf ? Shouldn’t this be month12003.inf? If so I have that file.
gre, to get this time last year on the trends, you need month12002.inf
That makes since. I didn’t keep that data when I rebuilt the PC last year so that why. Thanks for explaining it to me.
122002.inf is there in the datafiles directory. I just installed 9.42e so will check if it gets updated on the next cycle…
Nope, last month is still blank.
BTW, windrun is now up to 471.8 miles, should be only 161.0 wink
Also, are you anywhere near Hamilton? And is there a connection between the city and you?
month122002.inf is the filename
what happends wehn you clcik on refresh
wind run i have not got around to looking at (the data is there OK, just not beign calculated correct)
they are all there. click refresh where?
i\wdisplay\datafiles\24hourrain.inf
i\wdisplay\datafiles\direction.inf
i\wdisplay\datafiles\fwi.inf
i\wdisplay\datafiles\graphdata.inf
i\wdisplay\datafiles\latest.inf
i\wdisplay\datafiles\lightning.inf
i\wdisplay\datafiles\month102002.inf
i\wdisplay\datafiles\month112002.inf
i\wdisplay\datafiles\month12003.inf
i\wdisplay\datafiles\month122002.inf
i\wdisplay\datafiles\month82002.inf
i\wdisplay\datafiles\month92002.inf
i\wdisplay\datafiles\monthextra102002.inf
i\wdisplay\datafiles\monthextra112002.inf
i\wdisplay\datafiles\monthextra12003.inf
i\wdisplay\datafiles\monthextra122002.inf
i\wdisplay\datafiles\monthextra82002.inf
i\wdisplay\datafiles\monthextra92002.inf
i\wdisplay\datafiles\week2.inf
i\wdisplay\datafiles\FWI.txt
i\wdisplay\datafiles\tide.wxt
refresh on the trends page
dont know why its not working for you when it is for me
refresh has no effect.
try resetting the data files location
nope. that had no effect. I even tried actually making a new directory, and copying the files over to it, then resetting WD to that new directory and it had now effect.
anyone else have this problem?
i tried a new install, and only this and last months data files
works
but some one has emailed me to see it doesnt for me
so it must be some difference in date handling on different pc;s
I will have to add some debug code…
try
vers 9.44a
and then go to view, program error log, to see what it reports
“trends last month file=
c\wdisplay\data\month122002.inf”
is that correct?
looks to be
zip and email me that file then
note:
you would need to have good data this time a month ago…
