我的气象站被伪造以及滥用我要如何处理
不知道走什么时候开始,我的气象站BG4WDV-13在APRS.FI网站上显示异常数据。我尝试将我的TNC设备离线,但这个气象数据依旧源源不断在上传,可以判断出有人伪造了我的信息在传播数据,我应该如何做?
I don’t know when to start walking, but my weather station BG4WDV-13 shows abnormal data on the APRS.FI website. I tried to take my TNC device offline, but the meteorological data is still being uploaded continuously. It can be judged that someone has forged my information and spread the data. What should I do?
Is it possible that you are running some weather software, like Weather Display, that is sending the APRS information over the Internet rather than (or in addition to) through your TNC?
通过查看原始数据,可以看出数据源来自非我的TNC转发,我只有一台设备传输数据。 Login – aprs.fi – live APRS map
2024-12-15 18:13:29 CST: BG4WDV-13>APRS,TCPIP*,qAC,CWOP-4:@151013z3557.75N/12645.04E_231/022g030t-064r111p145P108h47b08382L068eoMeBEzejC
That looks like a CWOP packet. Are you uploading data seperately to CWOP and they’re re-transmitting it?
感谢您的提醒,我之前有加入过CWOP,我先尝试联系CWOP的管理者,看看是否能获取帮助。但是我依然无法理解,我作为数据发布的源头,无论是APRS.FI或者CWOP之类的,当我停止了我的数据上传,这些数据依旧在已很高的频率发送至网站并进行了转发传播。对于这种伪造、滥用目前有什么应对措施和办法嘛?
If you’re not sending your data then I’m not sure how anyone can be copying it?Does the data being published match your own current data or is the data being sent using your callsign for some other location?
Are you using Weather Display to collect data from your weather station?
通过查看原始数据,只有通过BG4WDV-10转发的数据才是我的。通过CWOP转发的就是伪造的。
如果您不发送数据,那么我不确定怎么会有人复制它?
RE:目前实际情况就是有人在冒用我的身份在发布数据。
发布的数据是否与您自己的当前数据匹配,或者是否使用其他位置的呼号发送数据?
RE:发布的数据完全是混乱的。例如温度、湿度、风速、风向等数据完全是不符合地球环境的数据。
您是否正在使用 Weather Display 从您的气象站收集数据?
RE:没有。
I understand now.
I think that all you can do is notify CWOP. They probably won’t be able to stop whoever is sending the incorrect data but they may be able to prevent the data from being included in the APRS feed.
I have tried the translates function on these posts Chris but get error 502 hope you had better luck
I’ve restarted the translator and it’s working OK for me at the moment.
