Steve are you using the latest version of WD? There was an issue with the switches about 6 months ago. Brian has since fixed that and I have not had any issues with them since.
You could also edit the wxtide32.cfg file, It would be easier than fiddling with the switches.
Thanks Steve I am using the latest version of WD no change for me when I use the switches unless you need to wait some time??? I will edit the config now and see how it works !!
I’ve tried all the above I still have the changes in the config since last night and nothing has changed with the tide time…I can change the time 1 hour + or - for my dial but not the rest of the tides table…
No change Mark it’s still the same output as mine minus the dial and the graph at the bottom…It has to be something in the tide_process file or something not sure!!
// If you do not want to show moon phase icons in tides put "yes" below //
$TmoonPhaseOff = "no"; //
// If you do not want to show moon phase icons in Sun & Moon times put "yes" //
$SmoonPhaseOff = "no"; //
I have both of them set to yes that took away the icons BUT the info is still there I see most everybody else’s tide table does not have anything but High and Low tide which is what I want…
I see yours doesn’t do that I’ve messed with everything I can think of and I can’t get rid of it sometimes it will say falling and rising also which I don’t want!!
