My old oregon scientific wmr100 has done its glory days, and I think its time for an upgrade.
Was recomended a Davis Vantage Vue? And a serial weatherlink`, was more stabel than the usb weatherlink i got told?
Some questions:
Is this a good station for the price? Better Than WMR200? Any other station recomandations?
Will it work nice with weather display and weather display live?
Is the serial or the usb the way to go?
If serial would you recomend a good serial to usb converter , or shoul i go with a pci serial card?
The console runs on a plug style transformer, my (UK) one says input 200-240v so I suppose the US version might not work here.
(Apart from the different style plug which is solvable)
You could run on batteries though, three C type are supposed to last at least a year.
Okei, thanks for the advice, might be better to just pick one up her in Norway then… To be safe, will be better when coming to warranty and stuff aswell.
Any other thougts on the USB - Seriell ? What to choose there? Anyone no a good seriell to usb converter that for sure works good with the davis?
Given the problems I have had with my davis vantage pro2 quality wise I would go anywhere near a davis product see my post.
You want to try buying the product in New Zealand about $1700NZ
Only one agent in NZ from what I can tell who knows how to charge and not provide service
Karl
I don’t know where in the world you are, but at least in the U.S. a Vue ISS + Envoy will cost you more than a complete Vue so you would pay more for less functionality, and you can’t AFAIK add a solar to a Vue, you need a VP2 ISS for that.
So I can say use a complete vp2 with a serial weatherlink? I dont then need an envoy?
I originally was set on a peet unit but decided it would be nice to be able to have solar etc and I found the peets didnt even have the basics. Very confused now. I hate it when theres a huge amount of choice :roll:
Yes, the weatherlink unit fits in the back of the VP2 (or Vue) console, no need for an Envoy. The VP2 can add the solar (and UV) sensor which connect direct to the ISS. The leaf moisture is a separate wireless unit that communicates directly with the console. The advantage of the VP2 is that the anemometer is separate from the ISS so you have much better installation choices.
