The solar sensor has no data in testtags.php, WD [Resolved]
Hello,
I have a problem with the solar sensor, which has values ​​in the monitor, but no values ​​in WD, testtags.php. I tried with several WD variants from 148 to 152 but without result.
Can I receive a suggestion to fix it.
Marian
Hi Marian,
In WD’s Weather Station Type Selection, have you ticked the “I have solar” option under Davis VP/VP2/Vue Settings:
I have solar and UV as you can see by the box ticked in my Weather Station Type Selection. You can see WD plots both: Clayton, NC Weather - Trend Graphs
Bill
. . . and is the solar Main Switch on
in Control Panel > Solar Sensor?
Thanks for the suggestions. I checked the settings for the solar sensor, it looks like in the attached images. Unfortunately, no result, still no data appears in tesstags.p.., only on the Davis console
You are not using a solar sensor in a jar so I think that should be 0:
That was the mistake.
It’s fixed!
Thanks a lot for your help
Marian
https://www.celinmeteo.com/wdisplay/RSS-HPV-webcam-en.html
