The Personal Weather Widget works again
A heads up for the previous users of this widget
Hi, I had to have my phone repaired over Xmas and in the process it had to be wiped, I got it back a week ago and reinstalled everything from backup and this clientraw widget is working 100% as it should and has been for a week now.
:thumbleft:
I like it too.
It’s on the homescreen of my phone and I am looking at it every day, multiple times.
It’s great.
Sometimes it locks up but after deleting and installing it again, it works right away again.
I had the lockups but no longer
Just tried to install on my android s22 and its installed (so it says) but not showing anywhere???
Seems to be working on my Samsung A50 phone, Ill try my tablet later.
swright1957: Having installed it you have to go to widgets (press and hold an open area on one of the home screens) and add it to one of your screens. Once on a screen you press and hold the temp to get to the configuration screen.
Regards, Jim
#-o
forgot that bit :oops:
It’s working well for me on my phone and tablet, the only hiccup I see is that changing text size and getting it to display the change seems flaky. Sometimes I need to force stop it and touch to update and the text changes.
Hello
all working on my phone now with the widget (Forgot its a widget) and yes as Broadstairs has said have to force stop it to make any adjustments (eg wind= mph etc etc)
Thanks for the tip regarding force stop, i tried to adjust the text size only yesterday and it failed so i just ignored it, now set as it should be.
