I only noticed this morning in the freshwdl application that letters that contain hooks and commas are replaced by a question mark.
To check, I installed an older wd version of the S120 and everything returned to normal.
I reinstalled the S133 version and the problem returned.
I enclose two pictures, the first version 133 and the second version 120.
This is the text of the current forecast conditions that wd broadcasts.
yes, i did change the code , as I had put the code into a thread
I did try and make sure the variable is UTF8 still,but it looks like its not fully working
the forecast string is not now used e.g for WDL, but I guess its still used for some other services?
i.e where are you needing this?
try a new .zip update and let me know
So unfortunately no change.
If there was a problem I would have to rewrite the text without hooks and commas, but it would also appear in the summary gif without diacritics.
i know what is wrong now
its the file save function
I know how to fix
I will let you know
it should be OK now .another new .zip update
Yes it works, great thanks
