testags.txt V1.06
I am searching for testags.txt V1.06
Any idea where i can find it ? I look all around the forum and did not find it !
Hi Jean-Robert,
The current testtags.php template (V1.08) is in the WD-plugin.zip in the WXtags-template-files/ directory as testtags.txt
I’ve attached one here too :slight_smile:
Ken
testtags.txt (47.2 KB)
Hi ken
Thanks ! Thing is that since i upgrate to v1.06 i guess, my comparaisin script does not work anymore !
Thankyou
Jean-Robert
Saratoga Hello, I downloaded the package to be reported within this package should be the last version of the file testtags.php, I opened the file testags.php present in the package, but does not seem to be the latest version available opening the file … says this inside:
/ / Converted to tagslist.txt. \ Tagslist.php for php tags
/ / By PHP-Jan-tagslist.pl - Version 1.00 - 07-Apr-2006
/ / Author: Ken True - webmaster-weather.org
/ / Edited: 20-Apr-2006 to trim unused tags
/ / Version 1.01 - 25-Jan-2008 - added-rain Windy icon to list
/ / Version 1.02 - 24-Jun-2008 - added variables to replace old with inc.html trends-trends-inc.php
/ / Version 1.03 - 27-Oct-2008 - added Snow and WU almanac variables
/ / Version 1.04 - 03-Jun-2009 - added moonrisedate / moonsetdate for wxastronomy.php
/ / Version 1.05 - 11-Jul-2009 - added tags for printable flyer, alternative dashboard, high / low / avg plugins
/ / Thanks to Mike and Scott for Their permission to add the tags above!
/ / Version 1.06 - 12-Jul-2009 - added tags for V4.0 of alternative dashboard
/ / Allow viewing of generated source
I went looking for the latest testtags.txt file, but all the archives I found on Saratoga only had up to 1.06, and nothing later but I knew there was a 1.07 available somewhere.
Thank goodness I came across this thread to see that there’s now a 1.08 version available. :slight_smile:
The WD-plugin.zip that Ken linked in his above post has testtags.txt version 1.07 (but the testtags.php is 1.06 which is confusing). The .txt is the one needed for setup and will generate your own testtags.php version 1.07.
