Tempest Weather with my own extra sensors
Hi all, I have just purchased a Weatherflow Tempest station, and would like to import some my own data into Weather Display, I already have a raspbery pi station and would like to add indoor temperature etc to WD as well as the data from Tempest, can this be done, if so how.
Many Thanks Michael
Hiya Michael.
I don’t have an answer for you, but I am interested as well. It would be great to pull in data from different stations/sensors, but I got to imagine that would be tough to put together. I bought a Netatmo ( I know, it was only $20!), it would be great to pull in the CO2 and noise levels into Weather Display with my main Ecowitt station.
I believe it can be done. WD is extremely capable. For instance, I use a VP2 for main data and I am able to import data from the Tempest station for solar/uv/lightning strikes. My guess is your idea could be done but would most likely require Brian to either modify the code, or, more likely could figure a way to configure WD with existing code.
Hi Thanks for the replies. My homemade weather station uses the Stationless CSV import option, it would be good if this cxould be used for extra sensors. Hopefully Brian may read this post and see if it can be done.
Michael
Unfortunately Brian rarely visits the forum these days. If you want him to see your suggestion I would advise you to send it to him by email.
