Temperature Sensor For Labjack
Hi All
This sensor will work on Labjack, cost is less than $6.00 US, same quality as expensive one. Added pot to calabrate temp I found it hard to to get temp exact. Pot is mounted at Labjack I have about 120 feet twisted shielded wire.
Joe :slight_smile:
good work!
hey, if you are handy with a soldering iron, and can get hold of one of those IC’s, (i.e from your local electronics store you should be able to get one) then thats a big cost saving!
maybe you could make some up and sell to people zeppline?
Thanks for posting that :slight_smile: I was going to get around to drawing a diagram lol
note that you only need to run the two wires out to the sensor so 4 sensors can run inside via one UTP cable :slight_smile:
