Temp Dial on main screen
Question…
Can you put a temp dial on the main WD screen..
There are wind and direction so can you put a temp dial??
Any ideas, or is this another email to Brian?
I’m not sure there is such a thing in WD. . . View > Weather Dials only has thermometers :slightly_frowning_face:
There is one in the WD app for iPad and Android, but it wouldn’t match the wind dials :wink:
Thanks BOS will have to find that and have a look.
There is a tempdial.gif (or jpg, if you select jpg’s) and i think you enable it from Control Panel-> Web Files Setup-> Web Files Setup #1, near the bottom of the page Produce Individual Dial image files. Then in Customize Interenet and File Creation, number 7 to set create and upload. To use just on the main screen, set a create schedule, but no upload schedule.
Put on the main screen through Setup-> Advance Misc Setting and use a custom image.
Jim
Hi Jim~
Yes i managed this at the weekend, so good BUT now just need to get it in the correct place and get rid of the wind dials on the mail WD screen.
Done this now and temp dial is now on the mail WD screen as I wanted.
Can we see a screenshot?
Hold the line please caller
