Brian, take a look at the temperature and dewpoint plots on my website. They worked for a while after I installed 10.12L but they’ve been this way for some time now. Just a spike.
you have a one off bad low reading, and the scale has auto scaled to show that low point
now, you can, go to setup, graph setup, and set the maximum temperature range (which is in 0C), and tick to use that
i.e use say 30
and or once the spike moves off the screen, it scale normaly
and or use the graph correct,…see in the setup, graph setup
and you may have to scroll left to find the spike…
then click the mouse prior to the line,hold the mouse (left button), then release it on the other side of that spike
tehn click on set start and end %
then tick correct temperature, then click on correct
and if worked, click on save the data
Well, it started working again all by itself. I’m gonna leave it alone to see if it fails again.
thats because the reading moved off the graph, as i posted above, but it will still show on the longer term graphs…so i would try the graph correct again
