Althouth this is probably not the problem, it will work fine to simply set the address in VirtualVP to 127.0.0.1, unless you have multiple network adapters on different subnets, and need to specify which one VirtualVP should route through.
In the older version of Lantronix, there was an option for “Raw” available when setting it up for TCP/IP to serial. That needed to be checked for it to work. I don’t know where that option is for other versions of Lantronix software. On the VirtualVP page of the SoftWx websits is a link to the older Lantronix Redirector that I have instructions for in the addendum of the VirtualVP manual.
It worked fine here with the 127.0.0.1 address also, but for some odd reason WD would not see the VP reception value (came out as 0% when WD was in TCP/IP mode). It is mentioned in another topic of the WD forum concerning a ‘0 %’ zero reception was a problem. Other than that WD worked fine.
the reception data comes from a command to get that data from the console (its not part of the loop data)
I must not have set that up to use the TCP/IP route
I will look into that
