I ticked use VP ET for month ET and un-ticked plot WD’s own ET. Now the these don’t update on this screen: The graph (day 1 in this case) since day 2 will update tonight, yesterdays final reading, current reading. The month to date is OK so far. It is also plotting on the solar / UV graph OK, except during data extraction which it goes to 0 then recovers during real time.
2nd issue on this graph is the UV index should have a decimal point in it. I mentioned this before and you said it would be too hard to change since the data has been stored all along in two digit form (38 for 3.8) and changing from here on would impact passed data. Would it be possible to leave the data at 38 and change what it displays to 3.8. The scale would be one and the tip tool would be the 2nd place.
