I use a 800*600 solution for my monitor - as you see in the picture - I can’t see the whole setup menu for the Sun-Moon-Setup - it is impossible for me to get to the options at the bottom of the setup.
Maybe - is it perhaps possible to make a scrollbar at the right side of the Sun-Moon-Setup-Menu? So that it is possible to scroll the whole Setup-Menu? That would be great! Thx!
It looks to me that your toolbar is blocking the bottom of that window - can you grab the top bar of the window and move it up? (just tried mine and I can move it around with no problem - just put your pointer on the top title bar of the window, hold down the left mouse button, and move it).
Thx for the info Snowman. Yes - that is maybe a try worth - but I will not get the “full” setup window - there is still something missing at the bottom - but Thank you of course for your advice!
To Brian:
Thx for the advice with the maximise of the window - but there is no option to maximise the window - there is only the “X” in the right corner to close the Setup-Window - look here at the red number 1:
It is - at least for me - not possible to maximise the window - I can only close the window.
Therefore - when you Brian can add a scrollbar for this window - that would be great - Thank you very much!
Thx for the scrollbar in the Moon-Setup-Menu and that is now possible to maximise the window - works perfectly - now I see “options/settings” I have never seen before - wow!
