Sun hours differance between my 2 stations
i am in the process of testing my new Vantage pro 2 plus and have it running on a fit pc 2i win 7 wd version 10.37Q build 35, VNC accessible only
today it says i have had 1.03 (hh.mm) of sunshine and the graph look like this
i have looked at the vantage log file and the W/m2 value reached a max of 587 just after 2pm
to me the yellow line on this graph is wrong the most that gets to is 100.5% this is set as solar energy using sensor #2 in the graph setup and has a max value of 1500 in which is proberbly right for W/m2 but unable to see the W/m2 plot
my wmr928 shows i had 3.23 (hh.mm) of sunshine and this has always been on the low side solar from sensor in a jar set at 1.1-11.1
if anything i would of expected the VP2 to show a higher sun hour figure than the solar jar setup so i assume i have a setting wrong in setup but i cannot see which one to fine tune
before you ask for a sceen shot of my setup i have not been able to make print screen work via vnc
Harold
