Summary.gif and dailyhighlowbaroetc.gif Image size issues
I recently changed computers and upgraded from XP to Win 7. I followed the FAQ on this subject and installed WD into the root directory. I went through the Registry and changed an directory entry’s to reflect the new location of WD.
Generally worked well except for the two images in the subject line. Both of these images are truncated and do not show the whole image.
I went through the menus and reset my screen size to the default to try and rectify the problem but to no avail. I then resized both images and saved the changes. This worked for a while until the next upload to the web when both changed back.
I am a bit stumped and would appreciate some assistance with this. I have attached both files.
Cheers
what screen size in use?
also make sure to not set to use large fonts
Hi Brian
I have an LG LED measures 580 mm across the diagonal (I hope this is the right answer) Resoloution set to 1920x1080.
I reset the change from big display under setup/advanced last night. That fixed one other problem but not the two I posted about.
Cheers
Ok misunderstood the issue re large fonts, thought you were talking about WD settings. Changed Win 7 to default and much better thanks.
Cheers
I have come across another problem. Indexdial.gif is displaying on my website as per the attached file. Yet when I look at this file in WD under view menu it displays normally and all images can be seen.
I have tried resizing and saving it but that does not make any difference. Can anybody assist me with this.
Cheers Greg
its a related problem
to your windows desktop settings
one thing that might help:
change the windows title bar settings back to classic style, i.e not wide style
