Summary gif and condition image problem
My conditon image (cold, very cold, etc) started to only partially show up so I tried adjusting the size (height & width) of the summary image to try to make it fit better. Well things only got worse and now the summary image is loused up also. I tried removing the summary.gif from the Web server completely and reloading it with the same results. Any suggestions.
Cheers
MikeyM
Did you put your condition image on your site manually (in your datahtm file)?
If so, maybe try a
tag in between the summary image and the condition image…
http://home.ptd.net/~mikeym/summary.gif
If you look you will see that it isn’t the code or positioning but that the images are being chopped…
IIRC there has been this issue in the past but dang if I remember what the cause and fix was…
I guess I should have looked farther before posting…
OK - I did have a slight cropping of just a couple of my images which I couldn’t figure out.
The fix for me was buried in another subject, but I finally found it - worth a try
3rd post in this thread - thanks to Firewx!
http://discourse.weather-watch.com/t/15686
Thanks, I’ll try it when I get home from vacation.
Cheers
MikeyM
Thanks Snowman
That fixed it !!
:greenjumpers:
Cheers
MikeyM
Excellent!
