Hi folks, I’m running 10.37R316 and has been peachy with my Texas Instruments WLS-8000, but that has no functioning solar sensor.
A friend is moving and took down his Davis Vantage Pro, original. Its a bit off on temp and all, but my intent is to test out the solar function and plot it.
The console shows good temp, off on humidity, wind and direction are smack on. The solar value (no UV) goes from 0 at night to a wee bit over 1000 on this rare sunny day.
After stopping WD, starting it again and then doing a station select for the Davis VP, I set the baud rate and the datalogger to default with Rev 3, although both seem to work.
I get blinking green boxes, the wind and all data appear fine EXCEPT the solar value (shown about wind direction) is zero. I went to the solar setup and looked at the screen to see what the raw data values are, and they show zero.
I went through the FAQ and the wiki and have all things set according to the nicely imaged demonstrations of what the screens are supposed to look like, but I did not turn on the weather icons to be driven by the solar value since it is zero and would no doubt say dark on the screen.
I am feeding out a customtextOut.txt to drive GraphWeather, and the MaxSolarPossible value is tracking right, and is in agreement with the calculated value displayed in the solar setup show raw data tab. The value output from WD to the VPSolar is zero.
I have the little green ON switch set for the solar. I have the Solar Sensor (but not solar plus UV) check box checked.
Since ALL other data is flowing from the Davis and is displaying correctly I’m wondering what I’ve overlooked or not checked correctly.
Is there a selection on the DAvis that I need to check or toggle to get it to send the solar values out in the data stream?
Is there a way to see the data values coming in from the Davis and WD is getting them, to check what values are coming in, some sort of log that shows what the latest data grab was, and if so what is the column that the solar value should be in?
Thanks for any assistance you might offer. This is driving me nuts and I know it must be some little thing I’ve missed.
I’m SOOO close!
Dale
