I noticed my website was not updating which relies on the clientraw file set. Looking at the realtime FTP it was permanently in a reset loop. So I logged on with the same credentials from Filezilla and found the certificate had been updated (Letsencrypt) so OK’d and restarted WD as the realtime FTP was still in a reset loop. This did not fix it - it required a reboot of Windows 7 before things got back to normal.
Has anyone else seen this? Does anyone know why this happens and why it needs a reboot to get it working again?
I have the same problem
Weather Display FTP/Internet vers 9.29
Time/date:9:36:09 28/09/2022
Logging onto FTP server…*************
Connecting to FTP server at ************
OK
Connected.
220 ProFTPD Server (FTP Server) [::ffff:83.217.74.233]
USER=****
331 Password required for acdeinzebe@acdeinzebe
PASSWORD=****
230 User acdeinzebe@acdeinzebe logged in
TYPE I
200 Type set to I
Change to remote Dir /weer
CWD /weer
550 /weer: No such file or directory
141: FTP protocol error: 550 /weer: No such file or directory
Checking for next FTP agenda…
there are 2 more things to do
Doing ftp upload
there are 1 more things to do
QUIT
221 Goodbye.
OK
Disconnected.
That’s not the same as me, my issue is that it would not login and kept on resetting and trying again and failing to login, probably because of the change in certificate from LetsEncrypt. The reboot fixed it and has worked fine ever since.
