Stops at 3am every day
OK, I know I said I would not mention any more issues, But for some reason at 3am for the last few days, WD stops. I cannot find any reason for this
Is there anything scheduled to run at 03:00, either within WD or on the system running it? Maybe an update run or a system reboot?
Nothing that I have setup. I will put a loop into the batch file to counter it
I will check my code too see what happens
At that time
OK, at 3:10 am
WD linux version runs the wdstartdelay program and then exits
i.e it does a daily restart
but if that is causing a problem then I will make it so that its optional
Ah, ok. just checked and it was not set to executable in the folder. I changed it now.
that might help
but i have also made it so that its an option now
in the misc setup
in the latest update
I will download the latest update. But I am wondering if running it as root is not helping. Given that I am using Netatmo, I don’t need ports etc .
I switched to a non root user and the 3am restart occurred ok
