Still erratic extraction Davis - logger
Bryan, check out the logfile for 52004 :
18 05 2004 19 34 22.1 47 10.3 1022.0 1 4 270 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 35 22.1 47 10.3 1022.0 1 2 270 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 36 22.1 46 10.0 1022.0 2 3 270 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 37 22.2 47 10.4 1022.0 0 2 270 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 38 22.2 47 10.4 1022.0 3 4 0 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 39 22.2 48 10.7 1022.0 1 4 22 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 40 22.2 46 10.1 1022.0 1 4 338 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 41 22.2 46 10.0 1022.0 3 6 0 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 42 22.1 45 9.6 1022.0 1 3 90 0.0 0.0 14.7 157.0 25.0 18 05 2004 19 43 22.0 46 9.9 1022.0 1 3 0 0.0 0.0 14.7 157.0 25.0 19 05 2004 18 16 23.7 45 11.0 1020.7 3 3 284 0.0 0.0 14.7 157.0 25.3 19 05 2004 18 17 23.6 45 10.9 1020.7 2 4 298 0.0 0.0 14.7 157.0 25.2
As you can see the extraction is still completely erratic , going from 19:43 on the 18th straight to 18:16 on the 19th .
As a result the 18th is of course missing in averages/extremes to date screen . I also had this problem with the 12th - had to manually adjust the logfile in order for it to get registered in the averages/extremes too date screen .
Is any solution in the works yet for the carry-over when WD is stopped before the midnight - reset and restarted after 00:00 the next day ???
we are shifting house on tuesday
and then I will have my VP as a full time weather station (leaving on at this house), and then I will have the time/chance to fix all the problems with the vp data extraction
:wav: :wav: :wav: :wav: :wav: :wav:
Is the new place going to have DSL?
its been like getting blood out of a stone that information from telecom…
i have tried to enquire, using the existing peoples phone number,…
but I never get a proper answer
but as far as I can tell, nope :frowning: (the local exchange does not have adsl by the looks, and wireless is not good over water)
so I have to wait for the satellite 2 way to come available…which the latest I have been told is June…but I am not holding my breath…
and there is only 1 phone line there…drat,…
