Thats it got it bookmarked
Thanks much Andy
Thanks much Andy
HI
can somebody tell me where i can remove the lcd from the wind-dir gauge
Ole
In gauges.js drawDir(), you need to add an initialisation parameter…
params.lcdVisible = false;
its the led in windir i wil remove
no, around line 730
Hi Mark
That was the trick tanks
Ole
Hi Mark,
In version 2.2.2 the movement of the pointer is too fast for me.
it is possible to change the pointer speed? if so how?
greetings Klaus
You can specify an initialisation parameter to the gauges “fullScaleDeflectionTime”, this defaults to 2.5 seconds. So for example if you wanted to slow down the temperature gauge to 4 seconds, change drawTemp() and add the last line as below…
drawTemp = function () {
var params = extend(commonParams);
// create temperature radial gauge
if ($('#canvas_temp').length) {
params.size = Math.ceil($('#canvas_temp').width() * config.gaugeScaling);
params.section = _temp.sections;
params.area = _temp.areas;
params.minValue = _temp.minValue;
params.maxValue = _temp.maxValue;
params.thresholdVisible = false;
params.minMeasuredValueVisible = _temp.maxMinVisible;
params.maxMeasuredValueVisible = _temp.maxMinVisible;
params.titleString = _temp.title;
params.unitString = data.tempunit;
params.trendVisible = gauge.tempTrendVisible;
//params.customLayer = _imgBackground; // uncomment to add a background image - See Logo Images above
params.fullScaleDeflectionTime = 4;
To slow down all the guages, you could add it to he commonParams…
commonParams = {
// Common parameters for all the SteelSeries gauges
gaugeType : gauge.gaugeType,
minValue : 0,
fullScaleDeflectionTime : 4,
Thanks Mark, thats work perfect ! :D/
Do you have the ‘wxgraphs’ series of scripts on your server?
If so, have you set imgPathURL in gauges.js to the path to those scripts (typically ‘./wxgraphs/’)?
i don’t see the ‘wxgraphs’ series of script on my server ! i’ve to setup that in WD ? where ?
thks
Nothing whatsoever to do with WD. You can get the scripts at Broadstairs - A Personal Perspective. There is a good tutorial on installing (if you get stuck with the included instructions) at How to setup jpgraphs and wxgraphs. Make SURE you upload the scripts in the same directory the arrive in ; /wxgraphs/. Don’t scatter them loose at the root of your server.
There are numerous threads on the forum about getting them working.
Wondering if anyone can advise me where I can lengthen the time the VP forecast text before resetting thereby missing portions of the text and it resets and starts over. Thanks.
John,
I found that it was the “downloading” message that interrupted the longer forecasts. At about line 985 I made the following changes and it works better for me. The second change was because I found it disconcerting that each countdown would begin with 10 regardless of what was set in the config.
getRealtime = function () {
// setStatus(strings.StatusMsg); // removed so "downloading" doesn't interfere with long scrolling forecasts
// _count = 11; // 10 seconds timeout
_count = config.counter + 1; // changed so that new countdowns start at the proper number rather than always 10
countDown();
$.ajax({url: config.realTimeURL,
dataType: 'text',
cache: false,
success: checkRtResp,
error: checkRtError,
timeout: 10000
Jim
I think you have misunderstood why the counter goes to 10, then jumps to your configured timeout.
When the script kicks off an Ajax download it sets a 10 second timeout for the download to complete, after that it retries. So if the web server was unresponsive for some reason, and you had a 30 second refresh, you would see…
- 2 secs
- 1 secs
“Downloading…” - 10 secs
“Downloading…” - 9 secs
“Downloading…” - 1 secs
“Download failed, retrying…” - 10 secs
{download works}
- 30 secs
- 29 secs
… etc
When things are working well the sequence would be…
- 2 secs
- 1 secs
{download works}
- 30 secs
- 29 secs
… etc
What happens sometimes is the server response is so fast that the “Downloading…” - 10 secs only flashes up very briefly.
Thanks Mark, I see I was way out in left field on that one, I’ll change it back. I just thought it a little strange that the 10 would always flash up there but now understand why.
Was about to ask the same question about the ‘flashing 10’. Thanks, Mark, for the very descriptive answer.
:oops: dumb question how do I get the gauges to work??
http://www.n7xrd.tzo.com/wdisplay/web/gauges/gauges-ss.htm
