How do I set Steel Gauges to start up with Imperial settings it starts. It always starts metric.
https://www.railroadflat.org/weather/steel/sgauges.htm
Mike
Vantage VP2 Plus
Weather Display version 10.37s-b130
Steel Gauges version 2.7.0
Mike
Vantage VP2 Plus
Your page comes up in Imperial here :?
You seem to have changed line 161 of gauges,js to set… userUnitsSet = true,
That needs to be changed back to the default false value, then I can take another look.
Thank you. I also discovered that I needed to change line 160 firstRun = false, to true
Now works
Mike
Good.
All the variable initialisations below the two config sections are for internal use by the script and should not be changed.
Have to admit I’ve wondered about those settings, too, because they are still above the dire warning on line 195
