I nade the switch to using Piratecast long ago and pwsWD has been running fine. But now all of a sudden I am seeing this:
I delete the status.arr file but this error returns in a few days…
Your forecast data is 15 days “old”
The script which should read the data does not return correct data.
Go to the de bug dashboard → . . . wx.com/pwsWD/pWS_module_test.php
Click the bottom button → “Load files” and check the error messages
PWS_load_files.php (502) Darksky_______: time spent: 0.4907 -
PROBLEM => http_code: 500,
no valid data https://travelingrvwx.com/pwsWD/PWS_Dark_Pirate.php?lang=en-u
There can be multiple causes f.i.
I think this was the problem…
