Station not showing up on map
When and how do I get my station to show up on the station map?
If you have added your station as described here I think you have to wait for Chris to approve it.
I think I have followed the instructions correctly. Notify me if there is an issue.
I’ve just enabled your station so it should appear soon (caching delays things a little). You didn’t add a URL for your weather site. I cna edit your station to add it if you’d like.
You can use this for live data AWEKAS Stationsweb This is one I send data to. If you wish to replace my “handle” use Nikiski Station but if Oldalaskaguy is acceptable I would like to keep it. Also the City keeps showing up as Kenai, it should be Nikiski.
Sorry to be a putz, usually I can make these changes my self. Use this link instead AWEKAS Automatisches Wetterkarten System Thank you for all your help.
I think I’ve got it as you’d like it now.
I don’t allow users to update their own records, partly because it’s messy to set up a username/password system. People often forget usernames and passwords on little used systems so that requires more admin support. Also spammers like the ability to change things…they put a proper record in first, then when they think no-one is watching they change the link to their dodgy web site. For the few changes that are needed I’m happy to make them myself.
I just noticed that you added a marker onto the WxSim map. Do you have a WxSim web page that can be linked to?
I do not have a WxSim web page. I do not have any personal weather web page. I do have an Ecowitt page that can be linked here: Ecowitt Weather
Out of confusion I may have used the incorrect map to place the marker. I do apologize for being unfamiliar with how things are set up here. Bare with me until things are all sorted. Eventually I will setup a personal weather web page.
No need to apologise. It was easily fixed. If you need to make any other changes just let me know.
