I’m hopeful someone here can answer the question, since I have the same situation.
The only two stations I have that can bring in solar data to WD directly are the Davis and the Texas Weather Instruments 8000.
I have other stations I’d like to have show the solar data. It is much more useful that I thought it would be.
The two that do show it have sensors that connect to the station itself, and then WD reads the output of those stations and plots, displays and sends it on.
I have a couple Rainwise that were not designed to have solar radiation sensors (although now there are versions, but not the popular and affordable stations, and the Peet Brothers station which I’ve found to be very robust, but also does not have a solar radiation sensor attachment.
I would think that there must be a way, since there was an effort a year or so ago for Brian to adapt his program to accept input from a laser range finder to process snow depth data, and extra temperature sensors are spoken of, but I do not know how to do that (yet, I’m hoping to learn through your inquiry.)
I look at it as a ‘team approach’ to gaining all these values. The stations that ‘do it all’ are wonderful, but otherwise leaves many good ones out of being used to furnish WD with all the values we may be interested in.
The team might be a station such as the WXT520 or a Peet Brothers which produces the majority of the values such as temperature, humiity, wind speed, direction and so on, but then add on, stand alone devices which generate another function such as cloud height or in our concern, solar radiation, or snow depth. Those independent setups would have to produce a value in a form and range that WD expects, perhaps with calibration factors, and WD would have to know where to pick up those values (I’m speculating, but say in a named file in a directory, and have WD read that input and integrate it into the total weather display, whether or not it came from just one station.
I could see a snow depth setup writing it’s value to a file, say “snowdepth.txt”, solar radiation meaurements written to another text file such as “Solar.txt” and every time WD took in a data stream from the station, it would also look to these other files (if enabled through a check box to indicated it should do that) and make it appear as if all the data came in from the station, as designed.
Even my modest needs would benefit from this, and with WD doing so much and being so versatile, I’d hope that this was an option. I’ve never had the need to do it until now and would like to hear from someone who knows WD inside and out if this is even possible, and if so, how do you do it?
Thanks for raising the question and I hope we have a positive answer from one of the experts here.
Dale
